Is there a way to create a BOM list that shows the complete QTY total of every sub assembly regardless of how many assemblies there are that it is in? (I was told by a coworker that if a sub assembly is inside of an assembly that there are multiples of, it won't count all of the sub assemblies)
My ultimate goal is when I'm creating print packs I need to label the quantity of every part, assembly, and weld assembly for manufacturing. It starts to get tricky when I have multiple weld assemblies, especially when the same weld assembly is in separate assemblies. How can I make a document that just straight up shows me how many sub assemblies are in an assembly I created with multiple assemblies and multiple assemblies inside of those?
This is what happens to me (hopefully this example makes sense)
A (QTY 1)
> A.1 (QTY 1)
>A.1.1 (QTY 5)
>A.1.1.1 (QTY 5)
> A.2 (QTY 1)
>A.1.1 (QTY 10)
>A.1.1.1 (QTY 10)
But when I make the BOM it only shows A.1.1.1 as having 2 QTY, even though it correctly shows that A.1.1 has QTY 15
A normal sub-assembly will count.
A "weldment" will not because it's a multi-body part, not an assembly.
Which also use "cutlist", not BOM.
