Hi, I am new to Solidworks and looking for your help with Contours and Offsets.
How would you offset with a constant variation in thickness of a part. For example you have a Vase with an opening at the top and a belly then the bottom. I will show you a snip it soon. So its mouth is 1/8th thick, then as you go to the bottom passing the belly it increase to 3/8th. I need to cut this but not sure how to cut my block of Vase to match these thickness requirements because the thickness is changing AND THE CONTOURS change as well.
Use Cut Revolve features. On symmetric plane, draw inside shape (half) and revolve it.
Or make this "Vase" as one features. See bellow:
