I'm using SOLIDWORKS 2019.
I'm trying to use the Intersect tool to "fill" a tank and pipes with water.
This isn't available for assemblies so:
- first I saved the assembly as a part,
- then added a block of water to the part and
- subtracted the pipes from the water to get the intersection.
The dimensions of my original parts are linked to global variables in a common text file but the assembly-saved-as-a-part and the resulting intersection are not. Is there any way to link the intersection to the global variables, or possibly a workaround?
Thank you!
Part file is attached.
