I have been using the intersect command with some work around to get the desired result. I have to always make a copy of the part that would be consumed and this doesn't seem correct to me. Could you take a look at the attached image that explains my workflow and tell me if I have been missing something very simple.
Thank you,
You can use Indent command wit active "Cut" option
