Hi.
Having a drawing and adding break views to a drawing view, and then do a projected view carries over the break views - which is good (setting set in propteries).
But additional break views on original drawing views will not carry over - this can be issue when revising old parts/drawings that need update.
Any workarounds for this?
You will probably need to insert a break in the projected view. After than you may need to go to the view's properties and choose the option to "Align breaks with parent".
