Im struggling with an Inflatable Tube design for a rigid hull boat. At the rear the tube must be 550mm diameter. In the front the tube must be 400mm dia. Together with these dimensions, it has an elevation together with a bend. Can someone help me and give some advice, A simple sketch or files as an example will be greatly appreciated.
Kobus Potgieter
Is this what you want?
