While changing views either from orientation tab or using space bar in part/assembly environment, this message popup again and again on every click.
Version : Solidworks 2020 Sp3
Anyone else faced the similar issue?
Sounds similar to this:
Solution Id S-072486
Product SOLIDWORKS Standard 2016
Created 12/25/2016
Technically Reviewed Date 1/4/2017
Area Display
Sub-Area Viewports
Question
When I press a keyboard shortcut for the view orientation, why do I see the message ‘Changing this standard view will change the orientation of any standard orthogonal…’?
Answer
This message appears if you define a shortcut for the ‘Front’ command in the ‘View’ category.
To view and change the keyboard shortcut options, go to ‘Tools’ > ‘Customize’ > ‘Keyboard’.
The ‘Keyboard’ tab lists view orientations (such as Front, Top, etc.) in ‘View’, ‘Others’, and ‘Tools’ categories. Use the ‘Others’ category to define the shortcut key for the view orientations.
No, don't see that.
