I believe the best you're going to get is turning on "Read
File Contents" and turning off "Check Out File" in the User
Permissions. I don't think there's anyway you can keep them from
copy/paste to an external folder.
But, you have to turn Read File Contents for them to click on the
file and see the Data Card. This will also allow them to use the
View tab and see the file. You may be able to disable the Viewer
somehow, but I'm not sure how.
I would like to us Enterprise to create employee folders which
would be visible to all staff. I've created a file data card which
creates the folder and creates a XLS in that folder. The data card
associated with the XLS uses conditional tabs which determine which
data is presented based on permissions level. Confidential info is
contained in the XLS, so the file itself needs to be locked down.
Since this doesn't appear possible, I'll just plug the data into
the folder data card.
But, you have to turn Read File Contents for them to click on the file and see the Data Card. This will also allow them to use the View tab and see the file. You may be able to disable the Viewer somehow, but I'm not sure how.
Hope that gets you started.
