TMThe Merovingien24/06/2020
here is a thread to share, compare, discuss about some settings in PRTDOT and ASMDOT.
i noticed while updating SWx to SWy "a long long time ago, in a galxy far,far away..."
that somes settings change strangely,
and some setting doesn't update.
also, when doing a "real fresh new install", SW point DOT to the tutorial folder, but it's seems majority of these files are updated to math the current SW version.
i tried to bypass the "tutorial" and force SW to generate a new file, it work, but i don't know from where the new file is cloned from, and the setting inside are not interesting, or up to date.
i don't want to list all the settings, but some basics, and some basics-user(company).
For some of them, i already managed/adjust them with my preference.
(to go quick on some setting, 0=unchecked option / 1=checked option)
3D basic planes : (Front, Top, Right) creator, creation date, autosize
Annotations folder : in tree panel, right-clic, details
Cfg properties : feat. suppressed / Suppresed new compoents (ASM only) / specific color
Display State : Hide new comp. (ASM only) / Linked
Lights : type and values
Document Setting : (Cotation) remove zero on right for Dim / Tol / Property
Document Setting : (Units)
Document Setting : (Quality)
Document Setting : (Weldment)
Document Setting : (Plane) front color, back color, transparencie, intersection
3D basic planes
Annot. folder
Config
Display State
Lights
PRT
dlevin
29/09/1999 18:28:01
Autosize "on"
0-1
1-1
1-1
0-1
1-0
0-0
1
0
1
0
0
1
Amb.
1 / White / 0.3
Dir. one
1 / 0 / White / 0.1 / 0.3 / 0.3
not locked / +21° / +20°
Dir. two
1 / 0 / White / 0.05 / 0.2 / 0.3
not locked / -155° / +38°
Dir. three
1 / 0 / White / 0.07 / 0.3 / 0.3
not locked / -43° / +20°
ASM
dlevin
29/09/1999 18:30:03
Autosize "on"
0-1
1-1
1-1
0-1
1-0
0-0
1
0
1
0
0
0
0
0
1
Amb.
1 / White / 0.3
Dir. one
Dir. two
Dir. three
CotationUnitsQualityWeldmentPlane
PRT
Remove
Same as value
Same as Dim
mm 8
inch 8
deg 8
mm 2
kg
m^3
60%
0
(0)
1
60%
(1)
0
0
0
1
1
0
1
0
(1)
Green (0-255-0)
Red (255-0-0)
95%
1
ASM
Remove
Same as value
Same as Dim
mm 8
inch 8
deg 8
mm 2
kg
m^3
60%
0
0
(1)
60%
(1)
0
0
0
1
1
0
1
0
(1)
Green (0-255-0)
Red (255-0-0)
95%
1
