Aleksandr Sornikov
Hole size changes in Hole Wizard
Discussion created by Aleksandr Sornikov on Jun 22, 2020
I have added some customized hole dimensions in the Whole Wizard (M14x1, M16x1, M20x1 and so on), that caused the following issue: when I go to Edit Feature of the existing Whole Wizard element, its size turns to M14x1 from whatever it was. If I close the setting window without applying the changes, the size remains the same, otherwise it changes.
We have the same glitch on two PCs running the same version of SW2019 SP5.0. The Whole Wizard databases were changed individually on both PCs.
Has anybody come across the similar problem?
Thank you
