Hi
I'm trying to set the tolerance of a bore. The input shaft is supposed to be 14mm h7 and I'm trying to design the bore for press fit (P6). However, when I select P6 and then the hole tolerance, I get the following error:
Does anyone know what might be wrong?
P6 isn't an allowed value for a press fit hole. Only H6, H7, H8, P7, S7 and U7 are allowed.
See solution S-046387 in the Knowledge Base.
