JJJay Johnson18/06/2020
When I use the Hole Wizard to create a hole for a Flat Head Screw, the head thickness does not match the depth or diameter of the hole shown in SolidWorks. Is there a way to adjust for the correct depth and diameter? If not, then which is correct?...The screw model or the Hole Wizard geometry? You would think the standard should be the same for both.
