Is there a way I can use the isolate command in multibody part?
Sometimes the imported data I am getting from our customers are multibody parts, and I would like to work on certain bodies while hiding others the way I would use the Isolate command.
Is there another way to achieve this same result for these situations?
Mark
What about selecting some bodies, invert the selection and then hide these...?!
You also can work with selection sets, wich can be saved.
Show hidden bodies can be used to bring them back on the screen.
Display states may help also.
And don't forget: Use TAB to hide a body an Shift+TAB to unhide it again.
