I have a multi-body part configuration which configures different solid bodies depending on the configuration. For example, configuration 1 configures solid body-1a and solid body-1b, configuration 2 configures solid body-2a and solid body-2b, etc. I would like to assign different material to each solid body. I'm using the format $LIBRARY:MATERIAL@solid body@part name. The part name is "SGP_VCS.sldprt". As stated above, the solid bodies are 1a & 1b for configuration 1 and 2a & 2b for configuration 2. So I am trying to add the following column in my design table: $LIBRARY:MATERIAL@1a@SGP_VCS. I get the error message that the heading contains an invalid feature name "1a". Can anyone tell me what I have done wrong? If I remove the "@SGP_VCS" in the header it sets the entire model to my material instead of just the solid body. TIA
Keith
I've never bothered trying to learn all the syntax, but you can assign different materials to different bodies easy enough. Expand the Solid Bodies folder (or cut list folder) all the way down and right-click.
