Hi All,
I am a BIM Manager working in a project on-site that is currently in progress. For the facade, the subcontractor is modeling all the joints and fixings with Solidworks and it's a software that I do not control that much.
First issue is: They have sent just a small part of elements of one level and the file is already 500 MB (IFC File). Is there any way to reduce the file size? I cannot imagine what size is going to be when exporting one level.
Second issue: we work with a federated model and therefore I would like to be able to import their models with the shared coordinates, landing in the correct location. I have researched on internet but I have not found any place that explains how to acquire coordinates from another BIM file or software. Is this something that can be done in Solidworks? Otherwise, how do you coordinate with different consultants?
Many thanks for the help.
Antonio
Muy buenos días Antonio el primer punto se pued solucionar usando WinRAR o 7zip o compresores similares.
Respecto al punto 2 debes decirle a tu proveedor de servicios que diseñe todo con el eje Z hacia arriba.
Y con una grilla de coordenadas como tú la necesitas así cuando lo importes se pondrá en el mismo lugar que tú le diste.
Creo que para que te envíen un diseño grande Wetransfer puede enviarte archivos de hasta 2gb
O sino comparte con ellos una carpeta en Google Drive asi es mas ameno los nieveles de revisión
Si puedes enviame un ejemplo de archivo de lo que tú proveedor te está enviando para ver otras opciones más.
