Tang Foo Chiat
How to change Marco export Drawing to PDF,DXF,DWG with Revision
Discussion created by Tang Foo Chiat on Jun 16, 2020
I have a following code which is not allowing me when saving PDF/DXF/DWG with revision. This code only allow me to save Drawing Files and the Revision from Drawing Custom Properties. But our Company using Custom Properties data from Part/Assembly files.
I will appreciate if someone can help me in getting the save as PDF/DXF/DWG Drawing with revision correct. Revision get from Part/Assembly template.
