MQMatteo Quirino12/06/2020
I am struggling with the pin selection during a cable routing. After I have created the path of all the wires, I press "Edit Wires" and assign a wire to the path.
When I select the first connector, the software allows me to select one of the PIN from a top-down field,so far so good, BUT then when I select the second connector the PIN field is autocompiled with the first PIN in the top down menu and if I try to select a different PIN the top down menu becomes empty...I cannot select any PIN both for the first and the second connector.
I leave a short video where I recored the screen, hope it helps in calrifying the problem.
Does anyone have the same problem on Solidworks 2019-2020?
Matteo Quirino
