I'm modeling a wall for a garage (the frame work) and I don't want the studs to merge with the sill plates. I want them to look like studs. I am currently turning the merge off at every command.
You can hide bodies that you don't want merge (as you work) or work on your body/s with "Isolate". If Bodies are hidden, then the automatic mode will not merge your new features to them.
You don't HAVE to use weldment profiles to utilize the power of the weldment feature. The feature will turn off the merge option and allow you to group any bodies into cut list items.
Yes, Elmer was correct too, and simply to the point. But Mr. Mathers was also correct. I felt they where they same answer, Mathers just added a little more to his answer. Mathers was first and I think you can only mark
You could create custom profiles and use the Weldments (Structural Member).
That is what I did for my summer project...
