Hi folks,
I'm trying to design and test a 16mm aluminium hub similar to this product. However, the stress analysis comes back with rather high P1 stresses for 30Nm input torque:
Is P1 stress around the shaft holder supposed to be acceptable or is the product just not designed for 30Nm? If acceptable, how come? I thought 30Nm is meant to be fairly low. I've also attached the part.
Put a radius or chamfer there and see if it helps.
Stress concentration on corners.
Sim could amplify the problem because it use mesh which create lots of corners.
Usually we can "ignore" it from experience.
Still the stress will cause fatigue failure.
