Louis Fourie
PDF task quality issue
Discussion created by Louis Fourie on Jun 10, 2020
Latest reply on Jun 11, 2020 by Louis Fourie
Good day
I created a workflow in which I there is a transition that converts my drawings to PDF. Everything works exactly as I want it except that the pdf created with the task is not as high quality as when I open the drawing and use file save as pdf.
The dpi seems to be set to a lower level as 600dpi.
Anyway to force the task to a higher dpi? Under the Advanced conversion properties in the task properties there is an option for high quality but even with this ticked it still isn't as good as I would like it.
