Hello guys, I'm trying to reconstruct a 3D model from a point cloud data which is a text file. when I try to open it with mesh prep wizard it creates a bunch of little pieces rather than creating complete geometry by joining all the points.
I tried the regular method, first enabling "Scan to 3D" add-in later using the "Mesh prep wizard" command. But I'm unable to get the actual geometry.
Is there a special procedure to follow?
Below is the snapshot of the point cloud, Geometry obtained, and Geometry supposed to get (approximate)
Any help is much appreciated!
Thanks in advance
mesh_prep_wizardpoint cloud3d modelstopography
Geometry expected to get (approximate)
You could draw a spline through all the know sections and then set up some guides and do a loft.
Since it looks like you have three tubes you'll probably have to do each tube and then surface model the "Y" connector section.
