I have SOLIDWORKS Professional.
I am currently using version 2020.
Visualize cannot be started.
The message "Failed to get license" appears.
I thought that Visualize Standard could be used.
But is Visualize not available in Professional?
First off, are you using standalone licensing or network licensing? You should have a separate serial number for your visualize standard which does come with SOLIDWORKS Professional or higher. You also may have to reactivate your license in order to use visualize.
