I attempted to load the ESP SW after about 20 minutes error
message came up. I uninstalled the program and tried again. The
same thing happened. Now I cannot uninstall because windows does
not see the program although there are SolidWorks and SolidWorks
(2) folders below the SolidWorks Corp folder. The SolidWorks (2)
folder has 6423 files and 541 folders, so it does looks like it can
be uninstalled.
The error message:Error 1722 there is a problem with this windows installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action... etc
The error message: MSI file did not install correctly.
Code=1603; Command line string: INSTALLDIR="C:\Program Files\SolidWorks Corp\SolidWorks (2)\'
ADDLOCAL=PhotoWorksRender... etc
I bought this HP computer 2 weeks ago and upgraded to Ultimate. I have 8 gigs of memory and 750 gig hard drive. Any help would be appreciated.
try downloading windows installer cleanup from Microsoft website and install it,
use it for removing Solidworks which is installed incorrectly.
then you can login as administrator, turn off all anti-virus applications and try installing again.
