Hi
I'm trying to run stress on a simple arm where the left end is meant to be driven by a motor giving up to 30Nm and the right end is a load. Am I running the simulation correctly by fixing the end with the load and applying torque to the end where the motor shaft is connected to? Here's my simulation:
The torque and the fixture are applied to clearance holes to where the shaft and load will be bolted. Please note that the graphic for the torque isn't displayed as clearly as it should.
Looks like you have Torque/per item instead of Total Torque applied. That could be why your stress appears to fail (outside the elastic region).
