For some reason Solidworks PDM is not pulling the latest version of files, and it appears only to happen after a file has been approved.
Part2 created, approved, revision shows "A" in explorer. All good here.
Open Part2, not so good!
Shows Local version 2/2, that should be fine. That's the latest version, but Local revision shows A, but custom property shows Pre-A? That's no good...
If I choose "Get Latest" and check the box, OR check out the file... Everything is now Revision A.
So, (1.) how can I fix this and (2.) how can Local version be 2/2 but not be the latest version. which is apparently also 2/2?
Do you have the users setting set to always use the latest version?
