Hi everyone,
I'm new to Solidworks. I worked in RHINO 3D mostly and a little in FUSION 360.
In both software i had the option of having a grid plane . For me it helps me orient around the scene and get an Idea of the size of my objects.
Is there anything symilar in SW?
I'm using SW2019
Thank to anyone who might help!
Hello Robert, in the design area, on top there is "VIEW HEADS UP" toolbar. select eye symbol and grid on and off is available. you can use as per requirement.
Grid adjustment available under "option" where you see gear type symbol. and you can select as per your measurement require.
