Hi, I have recorded a macro for creating two centerlines with an angle between them. I have used a userform to change the angle between the lines as per required. But the problem is that when i am increasing the angle more than 120° it starts giving output 180 +120°.Can anyone please help me come out of this issue? Thanks in advance!
Here I have attached the macro here.
Can you attach a screenshot of the failure and which dimensions are not being generated as expected?
I just used the default value for the angle (47.68), and then generated another sketch with all values set to 130 and didn't see anything along the lines of what you describe, but maybe I am misunderstanding the issue.
Default Values:
Entered "130" for all values:
