I set up solidworks flow with goals.
I have specific goal with a variable that I would like to change and test to find maximum value.
For example I'd like to change RPM of real wall to find maximum POWER at RPM range from 5 to 120. Is this possible to automate?
Power goal has manually written RPM value which is actually "real wall 1" rotation. Power is calculated from Torque over Z axis and rpm.
This should address your question: https://blogs.solidworks.com/solidworksblog/2013/10/design-scenarios-for-fluid-flow-in-solidworks-flow-simulation.html
