RWRohana Wickrama Archchi05/06/2020
I am exploring Solidworks in the area of huge assembly modeling to do with top-down approach.
I have done a little bit using layout top-down approach. As per my current understanding, it is likely not the best.
- I see huge models are done using Solidworks. Need to to how those models may have been created.
Top-Down modeling
- What is the procedure to create an assembly composed of parts, assemblies, assemblies (also nested assemblies) of structural, sheet metal, plate works, shafts, surfaces, surface modeling, etc.
- Is there a master sketch approach?
I look forward to receiving help.
I am kind of getting there using 2D/3D sketches in the main assembly drawings where the children components are residing. The whole models update (for the configurations and non-configured dimensions).
Revised document is attached here to.
I will do the same with a master sketch (MS) part (instead of 2D/3D sketches in the assembly document) as well.
