I'm having trouble resetting the CommandManager tabs back to default configurations in SW2020. I've tried Tools > Options > Reset All with no luck. I'm also aware that I can customize the tabs from where they are currently, but I'd like to reset them back to factory settings. Does anyone have suggestions on how I can go about doing this?
Thanks!
UI customizations are stored in the registry. so if 1) you are comfortable editing your registry and 2) you are ok with losing (or redoing) ALL of your toolbar customizations, you can use the copy settings wizard to save out all of your settings besides the toolbars. then reset the registry (lots of posts here on how to do that - I'll let you search). then reload the settings you saved out.
