Task Scheduler won't export to DWG. I'm on 2019 SP5.0 the batch export to DWG stopped working. it runs and appears to work, but no files are ever created.
I also have #Task and it is doing the same thing. Has anyone ever experienced this? We went to #Task over a year ago because of this issue with Task Scheduler. it worked great in the free version. then once we went to #Task 2.0, it does the same thing.
It doesn't matter if the file is located on the server or hard drive. It doesn't appear to make a difference if i run the programs as an admin. I thought it may be my export settings, but nothing has changed for years. Thoughts?
Hello Wesley,
There has been no changes to the macros between #TASK v1.3 and v2.0.
With that said, we do not have an option to control the Map Setting from Macro
Could you try to First Setup the Custom Map setting in SolidWorks. Enable Check Box and Provide a Map File.
Then Try Processing files using the Active Instance of SolidWorks.
Regards,
Vineet
