Is it possible to create the attached part?
The Part already has a shallow radius contour and I need to form (or pull) one top corner over about 3". It affects the existing bend and I'm not sure how to approach it. Any suggestions are much appreciated.
Thank you
The blue rectangle covers the area that is bent. The red line shows where the problem occurs. Unfortunately, this only with a bending machine is impossible without splitting the sheet.
