Hello all !
I've been desinging these tiles made with the Boundary surface tool by the combination of two perpendicular splines the outcome is the top surface of the tile, when you look on the part from the sides(attached pictures) it seems like the boundary surface is much higher and wider than the original splines,it is like the boundary surface is pointing out (up) much more than the original spline .
Is there a way to make the newly made surface to be exactly the same as the splines making it ? (without deviation from the original spline height and width )
Thank you!
Remi
I would try starting and ending your splines at a peak or valley - not in the middle of the height (you can cut off the ends afterward).
as it is now, the side curve is explicitly telling SW to go up from the front curve at the start...
