I recently did the CSWP segment 3 exam and failed it because of an error in the question at the beginning.
After I start the exam, I immediately got stuck on problem 3 because the assembly after mating does not match the image. However, I trusted the mating symbols and kept going.
Then later in problem 5 where multiple choices are given, I just couldn't match the correct center of mass coordinates in the options. I realize I'm off track and start looking for what the problem was. However, based on the instructions given, I'm pretty sure that I made no mistake elsewhere. The only possible error might be from the mismatch.
Now, I am super confused about what error I made. I really hope I can revisit the exam and take my time to see what error I possibly made. However, I understand this is not allowed.
The best thing I can do is keep practicing segment 3 and hope this will not pop up again.
Hey, please remove those pictures from your post. It's against the terms you agreed to to share information like this about the exam. I will Message you with a contact that can help you resolve this issue. For things like this you should be going through your VAR.
We can help you with general questions about the test, but sharing information that can give someone else an advantage on a specific question is a no go on the forums.
