Why can I pick sketch points only if I want to dimension sketch block entities outside "edit block" environment. Huge Bummer!!! I.e. I cannot add an angle dimension between two straigh lines.
If you pick entities it will stop you with a friendly "cannot add a constraint on this entity"
Maybe someone at SW can tell me why that is. I would be interested to know?
I believe that it is like trying to put an angle mate between 2 surfaces from the same component in the assembly environment. You just can't do it. That angle is defined and controlled from inside the component part file itself.
Inside your block, you should already have some sort of angle constraint (horizontal/vertical, perpendicular, angle dimension, etc..) between those 2 lines.
So then the work around here would be to add a phantom line, and dimension to that.
