Dispatch to check for possible duplicate filename when renaming
Question asked by Matt Martens on Jun 2, 2020
Latest reply on Jun 3, 2020 by Matt Martens
With Dispatch is there a way to find if a file with a certain name exists anywhere in the vault. I am able to check for an existing file when i know the directory it resides in but what if the file may exist anywhere in a vault. The rename action will error out but the script continues.
What I am attempting to do is rename files based on a variable but there will be instances when it will create a duplicate filename. In those cases I would like to use an OK message box with instructions for how the user should proceed. And because I want to run the dispatch script during a transition I need to be able to Cancel SW command.
