Just wondering if others had this issue. My tabs are always
switching positions. One day The assembly or some other tab is on
the right, the other day its on the left. Anyone else ?
My problem with the tabs is that the "Annotation" one doesn't
show up sometimes in a drawing when I need to use a command. I have
to open another drawing which loads the "Annotation" tab and then
go back to the other drawing that I was working on. I haven't
noticed or at least been hindered by a change in tab order.
Michael, The CM can be changed to have differenct options for
parts/assemblies/drawings.
Is this the switching of positions that you are seeing?
Tim, I don't use the CM anymore, but when I did, I saw what you are
saying. It seemed like it didn't switch to the drawing CM when I
switched to a drawing file.
I switched back to the assembly and back to the drawing to fix
it.
No, Im aware that they are different for a part file or Assy
file. It is the positions in the part or Assy file that change.
They are not in the same position from left to right from day to
day. I prefere my most used tabs to be closer to the center of the
screen, but they often switch places.
-Tim
