Linked revision table formatting across sheets
Question asked by Nicholas Ivanoff on Jun 2, 2020
Latest reply on Jun 2, 2020 by Frederick Law
I've noticed recently (likely with 2020) that linked revision tables now link the text size and column/row size. This is especially difficult when using multiple sheet sizes with linked revision tables. If I use a D-size sheet and an A-size sheet in the same document I have two choices: the revision table on the D-size sheet is too small to see, or the revision table on the A-size sheet is too big to fit.
Is there a way to unlink the format of the revision tables, while keeping the data in the table linked?
Edit: I should add that this is still an issue while changing the formatting after unchecking 'use document font' on the table properties window. I'm not using the Settings->Document Properties->Tables->Revision options to try to change the formatting.
