After updating to SW2020 SP3.0 I have noticed that the active file name is being cutoff by the search box. All I can see is the first few characters, anyone else having the same problem or know of a fix for it?
This should be fixed in SP4.
Received the following from my VAR yesterday:
The following SPR (SolidWorks Performance Report) status has changed to Implemented.
SR# (Service Request): 1-22815602531
SPR#: 1182109
Description: File name hides behind Search bar when you pin the Menu Bar if non-default Button (Icon) Size is selected
Status: Implemented.
Version: 2020 SP04
For more information, visit the SolidWorks Customer Portal and select My SPRs.
DS SolidWorks does not guarantee that this SPR fix will be available in the indicated future release of the product since at this time the SPR fix has not completed QA procedures that incorporate all SPR fixes and enhancements into a new version of our product.
Best Regards,
Dassault Systèmes SolidWorks Corp. Technical Support
Hi, thanks for addressing this issue...it has been one of the most annoying things about this version (especially during exams when I need to glance at the revision/question I'm on in the document). It seems like it should be an easy fix; hopefully we'll see it implemented in the next update.
Please request your VAR to submit an SR for this issue
