Get custom properties of the model from within a drawing
Question asked by Cameron Taylor on May 30, 2020
Latest reply on May 30, 2020 by Cameron Taylor
Hi
Using VBA Im trying to read the "custom properties" of the model shown in the "default model view" in a drawing
After scouring the web, I can now read the custom properties of the current document
ie
if the "model" is current then reading "Revision" I get "A"
if "drawing" is current  then reading "Revision" I get ""
Could someone please point me in the correct direction.
Option Explicit
Dim swModel As ModelDoc2
Dim swModelDocExt As ModelDocExtension
Dim swCustProp As CustomPropertyManager
Dim val As String
Dim valout As String
Dim bool As Boolean
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
' Get the custom property data
Set swCustProp = swModelDocExt.CustomPropertyManager("")
val = swCustProp.Get4("Revision", True, val, valout)
MsgBox "val = " & val
MsgBox "valout = " & valout
MsgBox "bool = " & bool
I ASSuME the "swCustProp" need tweaking
