Limit tolerance from excel
Question asked by Learning Expert on May 28, 2020
Currently I am using the below code to update the model based on the value entered in the excel.
I need to add the tolerance value which is available in the next call. Tolerance as a Limit one
Code which I used to update dimension,
Set Swapp = Createobject("Sldworks.application")
Set part = Swapp.Activedoc
OD = Thisworkbook.worksheets("Sheet1").Range("B2").value
Len = Thisworkbook.worksheets("Sheet1").Range("C2").value
OD_Tol = Thisworkbook.worksheets("Sheet1").Range("B3").value
Len_Tol = Thisworkbook.worksheets("Sheet1").Range("C3").value
Dbldiameter1 =Cdbl(OD*(25.4/1000))
Dbllength1 = Cdbl(Len*(25.4/1000)
Part.parameter("D1@Sketch1).system value =Dbldiameter1
Part.parameter("D2@Sketch1).system=Dbllength1
Can anyone help me on this to include the tolerance value (Limit tolerance)
