RRRamzi Rebeiz28/05/2020
My first question to the SW forums, patience greatly appreciated.
I'm having issues editing properties from within the assembly visualization (AV).
2018 SOLIDWORKS Help - Editing Property Values
the above link is what I'm trying to follow, but the "Editing Noncalculated Properties" is not working for some reason.
For example I would like to use the AV to change all the descriptions of parts and assemblies.
I added the property "Description" to one of the parts in my test assembly, gave it a random description
Now back to the assembly. It shows up correctly in the AV
And it looks like I can edit it, but It does not retain it.
I double click, edit, hit enter, and it stays with the new description in the AV
but back in the part, it didn't change. it's still the original description
And then when i come back to the AV in the assembly, it jumped back to the original description
If I change the property in the AV, open the part and DON't open the configuration properties, then go back to the Assembly, the AV retains the new value. But, as soon as I open the configuration properties in the part, it will show the original not the new property, and the AV will revert back to the original.
I run into the same issue with any custom properties.
Even if i make a completely custom property in a part, it still won't let me change it (without changing back) from within the AV (see below with "test text" which i entered from withing the configuration properties in the part, and tried to change to "new text" from within the AV)
I haven't tried every single property, but so far it seems that the only property I can change (without it changing back) from within the AV is "SW-Material".
Halp plz!
Ramzi
