I am new to Solidworks and need some help. I am trying to join two corners together of 4x4 structural steel in an assembly. I want the corners to meet at a 45 degree angle. The structural steel pieces lie in planes that are not 90 degrees to each other. Can somebody provide advice or fix this for me? I need all the help I can get. I have attached my parts and assembly files as well as a screenshot.
Hello, and welcome to the forum. I'm going to get pretty involved here, but I'll try to take it a step at a time. I'd post my files, but I'm using SW2020, so you wouldn't be able to open them.
1. To start, open your Part files and delete all those add-ons at the bottom of the tree. Next edit your sketch that created the first Boss-Extrude so that the origin is at the center instead of one end.
2. Add mates in the Assembly to fully define it's location. I don't remember exactly what mates were there, but delete any other than between the faces of the hopper and tubing. First a coincident mate between the bottom edge of the tube and the bottom surface of the hopper shell, then a symmetric mate between the tubing's right plane and the outer faces of the hopper.
Now it should be fully defined, and the ( - ) should be gone from the Part name in the tree.
3. Now create a new Plane in the Assembly, choosing the inside and outside edges of the hopper to define the plane.
4. Click on the tubing Part in the Assembly and choose the "Edit Part" icon. That will allow you to edit the part in the assembly, and reference other entities or components. Start a new sketch on the face of the tube that you want to extend and use "Convert Entities" to create sketch lines coincident to all the edges, inside and outside, then close the sketch. (Ignore the yellow lines in the screenshot.)
5. Use this sketch for a new Extrude. Choose "Up to Surface" and choose the Plane you created in the Assembly, and you'll need to select one of the long edges of the Part for the direction so it doesn't extrude perpendicular to the face of the Part. If the "Merge result" box is checked, un-check it.
6. The next part shouldn't need screenshots to save me some time. You can exit out of "Edit Part" mode, and open the Part. Use the "Mirror" feature to re-create the new extrude on the other end. Be sure to de-select the default "Features to Mirror" and select "Bodies to Mirror" instead, and then use the "Combine" feature to merge these three bodies into one.
7. Repeat the steps above for the other Part.
