PAPaul Aquino22/05/2020
Solidworks has a right-click flyout for Rename and does not work with PDM correctly. Basically, outside of PDM, you can right-click> Solidworks>Rename flyout function. However in PDM, when you right click on the Solidworks file and rename it generates a new file in the vault. Is there anyway to block this Solidworks feature in PDM? The issue is it doesn't really rename it, it creates a copy of the file and creates a local copy.
I know engineers can be trained, I just want to prevent anyone from using this feature. Since in PDM to rename it is just to check it out and do it in the data card.
