JUJake Uyeda20/05/2020
Hi Everyone,
I'm looking for some advice on the gap tolerance (not sure if this is the correct term) between mating threads. I'm going to be 3D printing with SLA to check. The plan is to make sure they screw together easily enough, however I'd like this gap tolerance as tight as possible.
Do you think 0.20 mm between the mating threads be easy enough to screw together? Or should I go with something slightly larger?
