I've recently upgraded from SW2020 SP2 to SP3, and found that my icons for New, SAve, SAve as Open, etc is missing in the header of SolidWorks.
And i can't figure out how to get them back.
Anyone who knows how to solve this?
Also, in SW 2020 SP 3.0 the Help menu is playing Find Waldo.
Bret Hekking, I am really curious why such a major UI change in an SP??? Shouldn't these type of serious UI updates be better introduced in major releases???
This unannounced update gave our Tech Support Team the opportunity to answer quite a few phone calls this week. Why?
Edit: For those of you who are wondering where Waldo disappeared:
Andrew Parkhurst wrote:
Alin,
Have you found where they've put the custom properties button then? I can't find it anymore after changing the layout back to some semblance of the past.
Did not change for me:
It is very easy to add it back, if it is missing. Just use Command Search and drag the icon in position:
Hi Klaus,
There is an option that has appeared in SP3 within the customize menu - "Quick Access Tools" by default this appears to be set to "Show in the CommandManager" rather than in the familiar place. Anyway if you swap this round, the tools will be back where you expect them.
