PPPichaiyan Prabaharan19/05/2020
Hi all,
I'm trying to rename all Sub-assembly and its components with running no.
But I got below issue,
   1. Its processing all components, but its not renaming all.
   2. Its not processing in order (Like Top to bottom).
Please help me to fix this..
Codes are here.
Imports System
Imports SolidWorks.Interop.sldworks
Imports SolidWorks.Interop.swconst
Public Class Form1
    'Declarations
    Dim SWApp As SldWorks
    Dim FileName As String
    Dim Type As Integer
    Dim Options As Integer
    Dim Configuration As String
    Dim Errors As Integer
    Dim Warnings As Integer
    Dim SWModel As ModelDoc2
    Dim swAssy As AssemblyDoc
    Dim swConf As Configuration
    Dim swRootComp As Component2
    Dim bRet As Boolean
    Dim bOldSetting As Boolean
    Dim errorsRename As Long
    Dim errorsSave As Long
    Dim saveStatus As Boolean
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        ' Get/Create SolidWorks
        Try
            SWApp = GetObject(Nothing"SldWorks.application")
        Catch ex As Exception
            SWApp = CreateObject("SldWorks.application")
        End Try
        Opendocument()
        SWApp.Visible = True
        SWModel = SWApp.ActiveDoc
        swConf = SWModel.GetActiveConfiguration
        swRootComp = swConf.GetRootComponent3(True)
        TraverseComponent(swRootComp1)
        saveStatus = SWModel.Save3(swSaveAsOptions_e.swSaveAsOptions_Silent + swSaveAsOptions_e.swSaveAsOptions_SaveReferenced, Errors, Warnings)
        SWModel.Rebuild(True)
        If saveStatus = False Then
            MessageBox.Show("Document not saved.!")
        Else
            MessageBox.Show("Document Saved.!")
        End If
        Dim result3 As DialogResult = MessageBox.Show("Process Done!""AEM Assembly Renamer Automation ", MessageBoxButtons.OK, MessageBoxIcon.Information)
    End Sub
    Public Function Opendocument() As SolidWorks.Interop.sldworks.ModelDoc2
        FileName = Assembly_location_txt.Text.ToString()
        Type = SolidWorks.Interop.swconst.swDocumentTypes_e.swDocASSEMBLY
        Options = SolidWorks.Interop.swconst.swOpenDocOptions_e.swOpenDocOptions_Silent
        Configuration = ""
        SWModel = SWApp.OpenDoc6(FileName, Type, Options, Configuration, Errors, Warnings)
        If Errors <> 0 OrElse Warnings <> 0 Then
            MessageBox.Show($"Error: {Errors}, Warning: {Warnings} ")
        End If
        Return SWModel
    End Function
    Sub TraverseComponent(swComp As Component2, nLevel As Long)
        Dim vChildComp As Object
        Dim swChildComp As Component2
        Dim sPadStr As String = ""
        Dim i As Long
        Dim swChildModel As ModelDoc2
        Dim NewName As String
        Dim RunningNum As Long = 1000
        Dim swModelDoc As ModelDoc2
        Dim swSelMgr As SelectionMgr
        Dim swSelData As SelectData
        For i = 0 To nLevel - 1
            sPadStr = sPadStr + " "
        Next
        vChildComp = swComp.GetChildren
        For i = 0 To UBound(vChildComp)
            NewName = "Modified"
            NewName = NewName & RunningNum.ToString
            swChildComp = vChildComp(i)
            swChildModel = swChildComp.GetModelDoc
            If swChildModel.GetType = swDocumentTypes_e.swDocPART Then
                swChildComp.Select2(False0)
                swModelDoc = swChildComp.GetModelDoc2
                swSelMgr = SWModel.SelectionManager
                swSelData = swSelMgr.CreateSelectData
                bRet = swChildComp.Select4(False, swSelData, False)
                SWModel.Extension.RenameDocument(NewName)
                RunningNum = RunningNum + 1
                Result_Txt.AppendText(vbNewLine & swChildComp.Name2)
            ElseIf swChildModel.GetType = swDocumentTypes_e.swDocASSEMBLY Then
            End If
            TraverseComponent(swChildComp, nLevel + 1)
        Next
        SWModel.ForceRebuild3(True)
           End Sub
End Class
Prabaharan
