How to change prefix which is automaticaly created (00_<filename>.dwg, 01_<filename>.dwg, etc.) after exporting to dwg? I need suffix numbers like (<filename>00_.dwg, <filename>01_.dwg, etc.) . It is possible to change it in SW or there is only one way to use macro?
Its probably file maintenance after the export.
Try Bulk Rename Utility - Free File Renaming Software
Kevin
