Hi all,
is there a way to change the custom property type from text to numeric using equation?
example - i have a custom property "TEST" with type as 'text' and value as "YES".
and i need the another custom property "TEST1" with type as 'text' and value as "1" if the custom property "TEST" has value "YES" and "0" if the custom property "TEST" has value "NO"
it is something similar to the thread link i have mentioned below.
Give value to cus.prop. with equation. - DASSAULT: SOLIDWORKS 3D Design - Eng-Tips
i dont want to use API but something that can be figured out using equations.
thanks in advance.
