Just says it "Failed to thicken a surface and cut from work piece". Any help is greatly appreciated. trying to thicken cut an offset surface.
You are probably running into a 0 thickness geometry issue (my SWAG).
So if you were to either start your cut outside the envelope of the main body (like, say 0.01") and then cut it into the main body, you might have more luck.
My advice:
Offset the surface of the letter so that the offset surface is outside the main body. Then run a thickened cut the thickness you need + the offset distance.
I don't work with feature much (ever), but I'm sure someone else will be able to help. It would probably be a lot easier if you could post the Part. See How can I attach a file to a forum post? if you aren't familiar with the process.
